Color Effects applied to channels show Error no channels were modified
I am trying to apply a linear effect to change the hue saturation values of a channel, but I get an error saying "no channels were modified". HS effect.JPG
Hue Saturation is likely not a parameter on these fixtures and Virtual HSB is not enabled
  1. In the CIA, go to Setup -> System Settings
  2. In System, enable the toggle to "Create Virtual HSB"
  3. Linear Hue-Sat effects should now work on channels with color data.
