Color and Text Indicators on Channels Tombstones
Color of Channel Number Indicator
The number at the top of the tombstone represents the channel, the channel number itself can show different meanings based off the color of the number. Here are examples of what you may see and their meanings.
Chan 1.png clipboard_e54d1bc37afb48561bd3d28272f73d29f.png clipboard_e7fc0f0237e4ccd276c5ceb07ed476bd9.png clipboard_eb261debab78c452fdddf8dd853a638d3.png clipboard_e07656155948c1d9c4fc4ae94c72c4eea.png clipboard_ebe0560c6f611396a1ad851f948bd4a79.png clipboard_e160e0771a8629140ded72c7dc65106ba.png clipboard_ea95e2be58ced77be6242758e011b5008.png
Patched Channel Parked Channel Deleted Channel Unpatched Channel Captured Channel Selected Channel Single Cell of Multicell Fixture Multicell fixture with Flexi Cells Off Mode
Color of Values in Tombstones
The values found inside the tombstone show the intensity of that channel, this may be reference data or a hard value. Either way the color of that value can represent where that value is derived from. Here are examples of the different colors you may see and their meanings:
Examples of Colors
clipboard_e10fdee6da6ac2d72e4b02bf7d19f9324.png clipboard_ea567f3beb76f217f92d48ff1fe146aec.png clipboard_eada0357afcb059f0e8ecc2ba7a175f5a.png clipboard_e441220ee7aff9bd4008dd15f4e0e3392.png clipboard_ee052c6b19588b6f41b564d86f221b902.png clipboard_e8eac7a4f935b61af2de2248679e45570.png clipboard_e0885b3e15a57492a64774308511a35da.png clipboard_e967b72151fd13c5d4485a8dbd5fdd14a.png clipboard_e79c8264935ed966c93b8018d3e896df0.png image (10).png clipboard_ee22047c63100f9b4e2b0c46f2b687da4.png
Bright Red Dark Red Blue Magenta Green White Grey Yellow Gold Brown Pink
Color
Meaning
Bright Red Manual data (any data that has been set but not yet stored to an active cue or submaster) on all consoles using the same user ID. When manual data is used, a red advisory "Manual Channels" will appear in the upper left hand corner of any Live display.
Dark Red Manual data from consoles using different user IDs than the console in use.
Blue Intensity value is higher than in the previous cue. Non-intensity parameters (NPs) are in blue when any move instruction has occurred. Unmarked.
Magenta Value is unchanged from the previous cue (tracked).
Green Intensity value is lower than in the previous cue. Also used in reference marking to indicate a channel is marked.
White Value is blocked.
Grey Unowned data. This could be a default value, data not currently being controlled, or a null value (from either {Make Null} or a filter). When null, a gray “n” appears next to the value.
Yellow Data set from a submaster.
Gold Data set from Staging Mode.
Brown Data set from a temporary fader (a palette or preset on a fader).
Pink Override data from an Augment3d Zone.
Note: When data is in transition (moving), it will appear in a lighter version of its color. This includes up/down fades for intensity, non-intensity moves from cues, submasters, and timed manual changes.
Text Indicators in Tombstones
Other than the color there are text indicators that can represent additional information on the values found in the tombstone.
Note: Color indicators also apply to text indicators. For example, red indicates a manual value that must be stored.
Here are examples of different text and their meaning:
Example
Indicator
Meaning
_
Underlined value (white) indicates a system-applied block (also called an auto-block).
Found in place of parameter data in summary view. Indicates that not all parameters in that category are at the same value. This indicator is found only in the summary view or in table views when the parameters are collapsed into a category view.
Indicates an ACN, RDM, or dimmer warning. IE: LED Sensor Overtemp.
Indicates an ACN, RDM, or dimmer error. IE: Fixture not powered.
A
Indicates the channel or parameter is asserted.
Not available on Element Classic
clipboard_e4a6d16b0081d6da9b597c8c199222235.png B Indicates the channel or parameter is manually blocked. This block must be stored.
clipboard_e1788433aedcd2017949c5e069e4b0b10.png C
Captured channel if in yellow. Color Path if in any other color.
clipboard_e9146c0d9d6f134ae5bd1db183f5fda81.png I Channel is controlled by an inhibitive submaster or grandmaster. When displayed in the Block flag, “I” indicates a cue level intensity block.
clipboard_e2740726aee5f808e0e86bc27be3621e0.png IP, CP, FP, BP Indicates that the value is referenced to a palette (Intensity, Color, Focus, or Beam). This text is followed by a number, indicating which palette is being referenced. This can be substituted with the palette label if the “Show Reference Label” setting is activated. Holding down [About] & [Label] will toggle between the palette label and palette number.
clipboard_efdc7814b486dfe15bd10f07e58019fbf.png M
Indicates a mark is placed, but manual, and must be stored. Is blue when stored.”m” indicates cue is not marking.
clipboard_e74f07a58187c291c47f07bfbe6077e0a.png MK
Indicates the channel is marked for a later cue. The cue number is indicated in the other categories (see “Q” below).
clipboard_ea2b1356ab96fed6903c0f6a873257ee1.png ND Indicates that a channel has been patched as a non-dim fixture type.
clipboard_ee54d38a6a12f5829201c571f59c85e6f.png N Indicates the value is null (from either {Make Null} or a filter).
clipboard_e1bdd1c6d90d5b57d8b4a565e9309bcc4.png P Indicates the channel is parked.
clipboard_ee7ee6642197e44769546272d051fe8e5.png Ph Indicates the channel is at a preheat level.
clipboard_ea6851cfb951b0738d412e2dd3169cdb3.png Pr Indicates that the value is referenced to a preset. This text is followed by a number, indicating which preset is being referenced. The preset label may also be shown if this setting is enabled. Holding down [About] & [Label] will toggle between the preset label and preset number.
clipboard_e74f07a58187c291c47f07bfbe6077e0a.png Q
Found in the non-intensity categories of a marked channel. The “Q” is followed by a number indicating which cue the mark is in preparation for.
clipboard_e3a7e0bc67dec4934b5fa419c5e499689.png t The channel has discrete (parameter/category-specific) timing.
clipboard_e22bc2fe63f99f6ead850ac7baea8c41f.png The channel has a Track SEM Focus Palette applied.
clipboard_e0afb34fcf34e7254948832a0a70ee4e5.png S Indicates that a channel is stored to a shielded submaster.
clipboard_e071200e777acad083bb0453c2af853a5.png R Indicates a manual reference override. Manual changes have been made that override a previously stored reference (such as to a palette or preset). Once recorded, the reference will be broken. If updated, the referenced target will be updated as well, unless otherwise instructed.
clipboard_e3d209f67d23cc4f8c2804c2f59bf3de2.png R
(grayed out)
In Blind, indicates a channel and its NIPs has the Release flag.
Release is an extension of the {Make Null} command in Blind. When Release is used, it behaves like Make Null, but it also releases the channel and parameter data to its background state, if one is available, or fades out the intensity instead.
Release can be used to mask instructions in a cue after it has already been stored. The data is not removed from the cue.
clipboard_efca9aa939f4521d7210e0f3f964fb223.png F, C, B
Below the intensity field there can be additional information for Focus, Color and Beam of a fixture (see "+"). That information can be suppressed by pressing [Params] and any parameter category (Focus, Color, or Beam) in the CIA. Doing so will leave only the intensity field and FCB indicators and the bottom of the channel.
On Element 2, Ion Classic and Element Classic, you will need to use [Data].
