Common Effects and How to Program Them on an Eos Family Console
For an effects video tutorial series, see our Introduction to Effects on Eos Series
Using Channels 1-10 as an example, here are some commonly requested effects, and step-by-step instructions on how to program them.
Intensity Effects
  1. Simple intensity chase
    1. Double tap [Effect]. Type [Effect] [1] [Enter] to create a new effect. Press {Step Based} on the screen (or softkeys) to specify it as a step-based effect
    2. Type {Step} [1] [Thru] [1] [0] [Enter] [Enter] to create steps 1 thru 10
    3. Press [Page Right] to advance your selection to the Channels column
    4. Type [1] [Thru] [1] [0] [Enter] to distribute channels 1 thru 10 to steps 1 thru 10
    5. Navigate back to [Live]
    6. Type [Group] [Effect] [1] [Effect] [1] [Enter]. This selects all the channels in the effect and applies the effect to them
      1. Note: "Group Effect" syntax only applies to step-based effects
    7. Hold the [Data] key if you can't see the intensity levels on screen
  2. Simple intensity chase with a build
    1. Navigate to the effect list (double tap [Effect])
    2. Type [Effect] [1] [Copy To] [2] [Enter]
      1. This makes a copy of Effect 1 in Effect 2
    3. Click on {Attributes} in the CIA and then click {Build}
    4. Navigate back to [Live]
    5. Type [Group] [Effect] [2] [Effect] [2] [Enter]
  3. Simple intensity chase with a bounce
    2. Type [Effect] [1] [Copy To] [Effect] [3] [Enter]
    3. Click on {Attributes} in the CIA and then click {Bounce}
    5. Type [Group] [Effect] [3] [Effect] [3] [Enter]
  4. A more fluid intensity chase
    2. Create Effect 4 by typing [Effect] [4] [Enter]
    3. Click {Linear} to create a linear effect
    4. Click {Parameters} on screen and choose {Intensity}. Press [Enter]
    5. Click on {Size} and type [1] [0] [0] [Enter]
    6. Navigate back to [Live]
    7. [1] [Thru] [1] [0] [Effect] [4] [Enter]
    8. Hold the [Data] key if you can't see the intensity levels on screen
  5. Same fluid intensity chase from the center out
    1. In [Live], type [1] [Thru] [1] [0] {Offset} {Mirror Out} [Effect] [4] [Enter]
  6. Same fluid intensity chase from the outside to center
    1. In [Live], type [1] [Thru] [1] [0] {Offset} {Mirror In} [Effect] [4] [Enter]
  7. Random flicker
    2. Create Effect 5 by typing [Effect] [5] [Enter]
    5. Press the {Edit} softkey to enter the edit mode, then the {Clear} softkey to erase the current line
    6. Draw a simple triangle by clicking in the lower-left corner, then the top of the INTENS line, then the lower right corner
    7. Press the {Apply} softkey to save your changes
    8. Click {Attributes} and choose {Random Group} on the screen
    9. Next, choose {Random Rate}. Type [5] [0] [Thru] [3] [0] [0] [Enter]
    10. Click {Cycle Time} then type [0] [.] [3] [Enter]
    11. Navigate back to [Live]
    12. [1] [Thru] [1] [0] [Effect] [5] [Enter]
    13. The effect is relative to the current intensity of the fixtures. You can change the base intensity level by typing [1] [Thru] [1] [0] [At] and then the new level, followed by [Enter]
    14. If you want to change the high point of the intensity for the fixtures, go to the effect and change its {Size}
    15. {Size} refers to how many points above the base intensity the effect will go. If the line drops below the center, the {Size} will refer to how many points below the base intensity the effect will go
Click here for an example video on Step Based Effects
Color Effects
  1. Color wipe from left to right across LEDs (just once then stop)
    1. Put channels [1][Thru][1][0] in a red color. (This can be done via the color picker ([Displays] -> {Color Picker}), ML Controls, or any number of other methods).
    2. Record Color Palette 1 by typing [1][Thru][1][0][Record][Color Palette][1][Enter]
    3. Create a new effect 11 by going to the effect list (double tapping [Effect]) and typing [Effect][1][1][Enter].
    4. Choose {Step Based}.
    5. Type {Step}[1] or click on Step 1 to select it
    6. Press the right arrow key to advance to the Channels column
    7. Type [1][Enter] to assign Channel 1 to the effect
    8. Press the down arrow to create Step 2. Type [2][Enter] to apply channel 2 to that step
    9. Repeat for Steps 3 through 10, applying channels 3 through 10 in order.
    10. Set the On State and Off State for each step to Color Palette 1. This can be done by typing {Step}[1][Thru][1][0]{On State}[Color Palette][1][Enter], pressing the right arrow to the Off State column, and typing [Color Palette][1][Enter] again.
    11. Click on {Attributes} then choose {Build}
    12. Click on {Exit} then choose {Stop and Hold}
    13. Return to [Live]. Put channels 1 through 10 at full by typing [1][Thru][1][0][At][Full][Enter]
    14. Type [Group][Effect][1][Enter]. This selects all the channels in the effect and applies the effect to them (only for Step Based effects).
  2. Same color wipe but from right to left (just once then stop)
    1. Back in the Effect List (double tap [Effect]), type [Effect][1][1][Copy To][1][2][Enter]. This makes a copy of Effect 11 in Effect 12.
    2. Click on {Attributes} then choose {Reverse}
  3. Same color wipe but from center out (just once then stop)
    1. In live, record Group 1 by typing (Channel) [5][Thru][1] [+] [6][Thru][1][0] [Record][Group][1][Enter]
    2. Create a new effect 13 by going to the effect list (double tapping [Effect]) and typing [Effect][1][3][Enter]. Choose {Step Based}.
    3. In {Step}{1}{Thru}{5}, assign [Group][1][3] [Enter].
    4. Set the {On State} to [Color Palette][1]. Also assign the {Off State} to [Color Palette][1]
    5. Click on {Attributes}, then choose {Build}
    6. Click on {Exit} then choose {Stop and Hold}
    7. In live, put the channels into the effect by typing [Group][1][Effect][1][Enter]
  4. Color chases using absolute effects
    1. In the Effect editor ([Effect][Effect]), create Effect 14, and select {Absolute}
    2. In {Action}[1], assign [Color Palette][1]
    3. In {Action}[2], assign [Color Palette][2]
    4. In live, put channels 1 thru 10 in effect 14
  5. Absolute color chase from the center out
    1. Copy Effect 14 to Effect 15 using the [Copy To] function
    2. In effect 5, set the {Grouping} to be [5]
    3. In live, put [Group][1] in [Effect][1][5]
  6. Rainbow chase
    1. Create 7 color palettes that represent 7 colors of the rainbow
      1. Select channels 1 through 10
      2. Change the color as needed
      3. [Record] [Color Palette] # [Enter]
      4. Repeat for the six additional color palettes
    2. In the Effect editor ([Effect] [Effect]), create Effect 16, and select {Absolute}
    3. Use the syntax "{Action} [1] [Thru] [7] [@] [Color Palette] x [Thru] y [Enter]" (where x is your first color palette in your rainbow ans y is your last) to assign your 7 colors as individual steps to this effect.
    4. Repeat Step 3 for all seven colors
    5. In live, select the channels and apply [Effect][1][6] to them.
Click here for an example video on Absolute Effects.
