Effect Not Starting With First Listed Channel
When I select channel A thru E and play an effect that has the channels change state at different times, the first channel(s) to change state is not A or A's group.
This is likely due to the Entry assignment in the Effect Editor. If it is set to Immediate, try changing it to Cascade.
