Eos Fixture Library Custom Manufacturer
I have a fixture whose Manufacturer is not listed in the Eos Fixture Library.  Instead, it's under the "Custom" Manufacturer when I search for it.
If the Eos Fixture Library includes just one or only a few fixtures from a particular Manufacturer, they may be listed under the "Custom" Manufacturer.  This shortens the total list of Manufacturers, as there are currently over 100 "Manufacturers" with only a single fixture in the Library.
The easiest way to find a particular Manufacturer / Model of fixture in the Library is to use the Search feature.
If the Manufacturer / Model for your fixture is not available in the Library, follow the suggestions in this post: I can't find my fixture in my Eos Family Console. What should I do? - Electronic Theatre Controls Inc
