External Monitors Beeping with Eos Family console
When I touch an external touchscreen, my console makes a beeping noise even if Sounds are disabled in the console setup menu.
Explanation of Issue
ELO monitors have a feature, which is disabled by default, to cause the internal PC speaker of the console to beep when touched.
  1. Exit to the console shell.
  2. Select Settings.
  3. In the General section of settings, select Monitor Arrangement.
  4. Select an ELO touchscreen.
  5. Select ELO Monitor Settings
  6. Select Touchscreen Properties
  7. Disable Motherboard Beeping.
  8. Repeat from step 4 until all monitors' beeping is disabled.
