Guide to remote operation of Eos via WAN
Preamble
This guide aims to highlight the various options for remote operation of an Eos console via a WAN (for example the internet).
Pros, cons, and design considerations will be outlined.
The best option for the environment will be based upon time, cost, and requirements. The final design should be evaluated for suitability before final deployment and ETC technical services are always available for advice.
This article is provided for informational purposes only. ETC does not officially support nor troubleshoot VPN implementation.
Overview of methods
Method Pros Cons
Native multiconsole
  • Very high level of programming/operating interface
  • 100% Eos experience
  • Requires no extra 3rd party hardware
  • Requires high bandwidth, low latency, high QoS; connection
  • Suffers poorly with network dropout and jitter
  • Requires at least two consoles
  • Security dependent on external encapsulation methods
KVM over IP
  • Medium to high level of programming/operating interface
  • Simple to implement secure connection
  • Requires medium to high bandwidth, medium latency connection
  • Requires extra 3rd party hardware
Remote Desktop
  • Variable level of hardware support
OSC
  • Low bandwidth requirements
  • Medium to high level of customisable operating interface
  • Low level of programming interface
  • Requires onsite personnel to change showfiles
Details of methods
Native multiconsole
Details
The best and fullest user experience can be obtained by using the native multiconsole features of Eos.
The remote site would operate an Eos in primary mode, with a local fully synchronised client.
Flowchart Placeholder
Network requirements
Eos multi-console operation was designed for Ethernet operation, and as such expects high bandwidth, low latency, minimal packet loss.
Discovery is based upon SLP (RFC 2608), and synchronisation via ACN (ANSI E1.17); these are mutlicast protocols so a single broadcast domain/layer 2 link is required.
To save bandwidth, DMX over ethernet protocols (sACN, ArtNet, et cetera) should be prevented from traversing the WAN
Minimum bandwidth
Variable - Show complexity dependent
Typically: 1.5 Mbps
Maximum latency
Ideal: <30 ms
Typically: <50 ms
QoS DSCP CS4
Hardware requirements
  • At least two Eos Consoles
  • (Optional) External VPN encapsulation hardware
Security
Eos multi-console operation is based upon ANSI E1.17 (ACN) which offers no native network security options.
Untrusted networks should employ external tunneling hardware, for example L2TP/IPsec
KVM over IP
Details
There are many commercial KVM over IP (Keyboard, Video, Mouse) devices available on the market.
A KVM over IP would connect remote monitors and USB devices (keyboard and mouse) to the Eos via IP.
Eos Programming wings should never be connected through a KVM.
Care should be taken to ensure the KVM maintains the USB connection when switched. Rapid connection/disconnection of lesser spec'd KVM will cause issues with interfacing hardware.
Minimum bandwidth Consult KVM supplier
Maximum latency Consult KVM supplier
QoS DSCP Consult KVM supplier
  • Eos RPU
  • 2x KVM over IP Gateways
  • Monitor
  • Keyboard and mouse
Security
Many KVM over IP devices offer built in security options, the level of required security should be specified at procurement stage.
Remote Desktop
Details
The Eos console would be connected via Multiconsole1 to a local PC, this PC would be running a remote desktop server.
The local PC, running the remote desktop client, would have a local control surface (for example Eos Programming Wing).
There are many remote desktop solutions available to suit different budget and environmental requirements.
It is recommend that the solution includes support for USB pass through.
1Some remote desktop solutions will disable the Eos dongle required for client mode. Please check compatibility
Minimum bandwidth
Variable - Consult remote desktop supplier
Depending on video size/refresh requirements: 1.5 Mbps - 15 Mbps
Maximum latency
Typically: <100 ms
QoS DSCP Consult remote desktop supplier
  • Eos Console
  • 2x PC with remote desktop software
  • Eos Dongle for "remote PC"
  • Eos Programming Wing
Security
Most remote desktop solutions offer built in security options.
This can be supplemented with VPN software on the PC or VPN gateways.
OSC
Details
Most of the Eos functionality can be access by Open Sound Control (OSC).
An application specified control surface can be created
There are many OSC controllers available in both dedicated hardware, or in software. A popular example would be TouchOSC (https://hexler.net/products/touchosc)
Minimum bandwidth Very Low
Typically: <512 Kbps
Maximum latency Typically: <100 ms
QoS DSCP CS3
  • Eos Console
  • OSC Controller
Security
OSC offers no native network security options.
