How to Run an Absolute Effect (Without Even Trail) on Two Groups of Channels
The Absolute Effect I created is intended to run on Group A and Group B simultaneously, however when I play back my cue the effect runs on Group A first and ends with Group B. How can two groups run the same effect at the same time?
If the Absolute Effect does not have an Even Trail, then the effect will run across Group A and B sequentially. Therefore, Group A and Group B cannot use the same effect.
- Duplicate the Effect A and record Effect B
- Apply Effect A to Group A and Effect B to Group B
- Now the groups will run simultaneously, as Effect A and Effect B trigger at the same time
