Saving an Image of a Magic Sheet
An Eos Magic Sheet can be saved as an image file for future reference.  When saving, the two main options are to save as a png file or as an svg.
Steps to Solution
  1. Go to the Magic Sheet Tab.
  2. Click on the arrow on the right side to enter Magic Sheet Edit mode.
  3. Zoom to the section you wish to save as an image, or use the Magnifying Glass icon in the top-right to Zoom to All
  4. Select the '3 Gears' icon to open settings.
  5. Scroll down to Import/Export and select the picture icon to "Save as image".
  6. Choose location, name the file, and click "OK".
NOTE: The default save is a .png, with the option to save as .svg.  Other formats can be saved by manually chaging the extension.  The following formats are supported for both  Import and Export:
bmp
cur
dds
ico
jpeg
jpg
pbm
pgm
png
ppm
svg
tif
tiff
wbmp
webp
xbm
xpm
So for example, you could save a JPEG file called "Magic Sheet 1.jpeg"
