Diskette Error Messages in Express
Bad Disk
Disk is unformatted or defective. Try formatting it. If that doesn’t work, try a different disk.
Corrupted Disk
This disk is defective. Try formatting it. If that doesn’t work, try a different disk.
Data not recorded on disk
You cannot read the System Configuration settings from showfiles created with software Version 3.02 or earlier. You must save the show with 3.03 or later software to include System Configuration settings.
Disk controller failure
Call ETC Technical Service at the office nearest you.
Disk full
Disk contains other files. Remove enough files to make room for show file.
File not found
This disk does not appear to have a show stored on it. Please confirm that you have inserted the correct disk.
No disk in drive
Show diskette must be inserted in the diskette drive before you can save or read a show.
Unknown disk error - try again
Try the diskette again. If it fails again, call ETC Technical Service at the office nearest you.
Write-protected disk
The write-protect tab on this diskette is open. Close the tab to unprotect the diskette.
