Encoder setup on Express consoles
Encoders are rotating level setting devices that are either installed in some consoles or available as an attachment. Express consoles do not use encoders but can make use of encoder pages to provide easier access to a number of fixture attributes.
The encoder Setup display allows you to change the assignment of fixture attributes among your level-setting devices and pages. For Express, that means you can choose which attributes are assigned to the two axes of the trackpad, TX and TY, for the six pages available.
The default assignment is to have the pan and tilt attributes on the trackpad for every page. That means you can retain the convenience of having the position attributes on the trackpad for one of those pages and make alternate attribute assignments on the remaining 5 pages.
Go to the Encoder Setup display
  1. Press [Setup] [1][5] [Enter] to display the Moving Light Functions menu.
  2. Press [4] [Enter] to go to the Encoder Setup display.
Navigation and Feedback - Encoder Setup
Purple coloration Attributes used in the show
Gray coloration Attributes not used in the show
Yellow coloration Encoder/page selections
White coloration Attribute field selected
Changing assignments
Encoders and other level setting devices are assigned to 44 of the 64 available attributes by default. You may change the default settings to suit your individual needs, such as to reassign attributes that you most commonly select to suit your individual setup or preferences. You may not, however, assign an attribute to more than one location on a page.
There are three ways to change assignments in the Encoder Setup display: individually, automatically and back to defaults.
Change individually
  1. Select a trackpad axis with the up/down arrows.
  2. Select Page 1 with the left/right arrows. Press [Enter].
  3. Select an attribute with the [+] or [–] keys.
  4. Continue making changes until done.
Change automatically
The console can make automatic level setting assignments for all fixture attributes you are using in your show. One reason you may want to use this automatic assignment feature is to ensure that all your attributes are included in the encoder setup (20 do not appear in a default setup). Another reason is to quickly concentrate your attributes on the lower- numbered pages, thus reducing the need to change pages when setting levels. Only attributes in the current show are assigned. pan and tilt are assigned to the trackpad on every page.
This feature is available as a softkey called Autoload Encoders in Fixture Patch or in the Encoder Setup display (in Fixture Patch, you may need to press [S7], More Softkeys, first). In the Encoder Setup display, press [S6], Autoload Encoders (you must press [Enter] twice to confirm). After executing an Autoload assignment, the Encoder Setup display resembles the one shown in the illustration below.
Resetting defaults
You may return to the default level setting assignments anytime you wish. In the Encoder Setup display, press [S7], Reset Defaults, and press [Enter] twice to confirm.
