Real Time Programs in Express
The console allows you to create up to 500 real time programs that can run automatically when you’re not there. For example, you may wish to turn on the work lights for a choir rehearsal between 7 PM and 9 PM on Monday and Wednesday. Or, warm the filaments of your studio instruments 15 minutes prior to your news program.
These programs run in real time, which means that they execute periodically when pre-set conditions arrive. These conditions include the time of day and either the day of the week or a date. The time settings can be absolute, such as 7:00 a.m., or they can be related to your local sunrise or sunset using the console’s astronomical clock feature.
You must do two things before you can properly execute a real time program. First, you must set the real time clock. The procedure for setting the clock is given under Setting the clock. Second, you must enable real time programs, which is explained in this chapter.
Go to the Real Time Programs display
Press [Setup] [1][2], Real Time Programs, [Enter] to go to the Real Time Programs display.
Navigation and Feedback- Real Time Programs display
  Screen Shot 2018-12-04 at 4.11.30 PM.png Screen Shot 2018-12-04 at 4.11.35 PM.png Screen Shot 2018-12-04 at 4.11.45 PM.png Screen Shot 2018-12-04 at 4.11.55 PM.png plus minus.png
White row Indicates program selected
Yellow coloration Indicates field selected
Enabling / disabling real time programs
Real time programs are enabled by default.
Follow the procedure below to enable or disable real time programs:
Keystrokes: Action:
1. Press [Setup]. Selects Setup display mode
2. Press [6] [Enter]. Selects Options Settings menu
3. Press [1][1] [Enter]. Prompt reads:
Enable/Disable real time programs (1 = enable, 0 = disable)
4. Press [1] [Enter]. Enables Real Time Programs.
Creating real time programs
You can create a real time program that references either the absolute local time or the astronomical times of sunrise or sunset. Also, you can specify either the days the program will run or a particular date.
Days and absolute times
Use this procedure when you want to specify days of the week and absolute times. Note in the footnotes to this procedure the substitutions that allow you to specify a date rather then days of the week and sunrise or sunset rather than the absolute time.
Keystrokes: Action:
2. Press [1][2] [Enter]. Selects Real Time Programs display
3. Press [S1], Select Program, [1] [Enter]. Prompt reads:
Enter time (12 hour clock) Press [+] to enter AM or PM
4. Press [8][0][0] [Enter].a Enters time to run macro.
Prompt reads:
Enter days of week (1=Mon, 2=Tue, 3=Wed, 4=Thu, 5=Fri, 6=Sat, 7=Sun) or press [Days/Date] softkey again for date
5. Press [1] [And] [3] [Thru] [5] [Enter].b Enters days to run macro
Prompt reads:
Enter macro number
6. Press [5] [Enter].c Creates real time program 1
Prompt reads:
Type program label (F6 = clear to end, F7 = previous program label, F8 = next program label)
aTo reference sunrise or sunset rather than absolute time, substitute steps A–C given under Referencing sunrise or sunset, for step 4 here. Then continue in this procedure.
b To reference a date rather than days, substitute steps A–D given under Referencing a date, for step 5 here. Then continue in this procedure.
c Labels are allowed in Express showfiles but cannot be assigned there. To assign labels for Express showfiles, see Expression Off-Line.
To reference sunrise or sunset rather than absolute time, substitute the partial procedure below as explained under Days and absolute times. This example sets the time to 10 seconds before sunrise.
Keystrokes: Action:
A. Press [S3], Astro Clock. Prompt reads:
Select astronomicaltime of day (0 = none, 1 = before sunrise, 2 = after sunrise, 3 = before sunset, 4 = after sunset).
B. Press [1] [Enter]. Selects before sunrise.
Prompt reads: Enter time offset (hours/minutes)
C. Press [1][0] [Enter]. Enters time offset before sunrise when the macro runs
Prompt reads: Enter days of week (1=Mon, 2=Tue, 3=Wed, 4=Thu, 5=Fri, 6=Sat, 7=Sun) or press [Days/ Date] softkey again for date
Referencing a date
To specify a date rather than days of the week, substitute the partial procedure below as explained under Days and absolute times. This example sets the date to 21 March 2000.
Keystrokes: Action:
A. Press [S4], Days/Date. Switches to date entry procedure
Prompt reads:
Enter date (0=all days of month) or press [Days/Date] softkey again for days of week
B. Press [2][1] [Enter]. Selects date=21.
Prompt reads:
Enter month (#1–12)
C. Press [3] [Enter]. Selects month=3. Prompt reads:
Enter last two digits of year or press [Thru] for all years
D. Press [0] [Enter]. Selects year=2000
Prompt reads:
Enter macro number
Editing real time programs
Once you have created a real time program, you can easily make changes to it and others in the Real Time Programs display.110 Press [↑] or [↓] to move from one program to the next. Press [←], [→] to move through program options. Although you cannot enter the label field in an Express console, you can label Express real time programs using Expression Off- Line. See Expression Off-Line, for more information.
Deleting real time programs
You can delete all real time programs as one of the Clear Functions reached from the Setup menu (option 12). Alternatively, you can delete one program at a time in the Real Time Programs display.
Delete a real time program with the following procedure:
Keystrokes: Action:
3. Press [S7], More Softkeys, [S6], Delete Program. Prompt reads:
Select program number(s) to delete, then press ENTER
To cancel, press CLEAR
4. Press [5] [And] [6] [Enter]. Selects programs 5 and 6 to delete
Prompt reads:
To confirm, press ENTER
5. Press [Enter]. Deletes programs 5 and 6
Inserting real time programs
Keystrokes: Action:
3. Press [S7], More Softkeys, [S1], Insert Program, [4] [Enter]. Specify insertion at program 4 Prompt reads:
Select program number to insert, then press ENTER
4. Press [2] [Enter]. Inserts two new programs starting with number. All following programs are renumbered
110 While editing a real time program, you can run it simultaneously because the editing procedure is buffered in memory. The changes are recorded once you leave the Real Time Programs display and or sort the programs. See Sorting/ recording real time programs.
Copying real time programs
Keystrokes: Action:
3. Press [S7], More Softkeys, [S2], Copy Program. Prompt reads:
Select program number(s) to copy, then press ENTER
4. Press [1] [Thru] [5] [Enter]. Selects programs 1 through 5 to copy
Prompt reads:
To copy selected programs(s), select time and press ENTER Press [+] to enter AM or PM
5. Press [7][0][0] [+] [Enter]. Copies program 1 to a new program starting at 7:00 AM; the rest of the programs maintain their original relationship in time
Moving real time programs
You may move one or more real time programs from one time slot to another. (To move a single program, you may also use the arrow keys to highlight the time for the program you want to move, use the keypad to enter the new time, then press [Enter].)
Keystrokes: Action:
3. Press [S7], More Softkeys, [S3], Move Program. Prompt reads:
Select program number(s) to move, then press ENTER To cancel, press CLEAR
4. Press [1] [Thru] [5] [Enter]. Selects programs 1 through 5 to move Prompt reads:
To move selected programs(s), select time and press ENTER Press [+] to enter AM or PM
5. Press [5][0][0] [Enter]. Copies program 1 to a new program starting at 5:00 PM; the rest of the programs maintain their original relationship in time.
Sorting/recording real time programs
The console simultaneously sorts and records real time programs according to time of day when you exit the display or when you move, copy or delete programs. You can force a sort at any time you are in the display by pressing [S7], More Softkeys, [S8], Sort.
