Express - How to Fix Intermittent Switches
Express buttons are not responding or are intermittent and may take multiple presses to register.
Explanation of Issue
When an Express console sits unused, dust and corrosion can build up inside the switch mechanisms and cause key presses not to register. Sometimes just pressing the keys and using the console again is enough to loosen things up and get the keys working again, but if that's not enough you can try the solutions below.
1) Create a Diagnostic Disk to Test Your Facepanel
Test the Face Panel using the Diagnostic Disk to confirm which switches are bad and later confirm that they have been fixed. Simply removing the disk and rebooting your console should return it to its normal mode of operation.
- Use a computer with a floppy drive to copy the face panel diagnostic file (FACE.BIN) to a floppy disk.
- Turn off the console, and then insert the disk.
- Turn on the console and low the disk to load.
- Select the "Face" test and press [Enter].
- Test all of the buttons and faders. Wiggling can help find intermittent issues.
- Press the button several times. This often will break through the corrosion and allow the switch to work correctly.
2) Create a Diagnostic Disk to Test Your Trackpad
If no switches fail the face panel test, a bad Trackpad could be the cause of the data entry or control issues. Run the Trackpad test (TRACKPAD.BIN) following the same steps as the Face Panel diagnostic disk.
- Once the Trackpad test has been loaded, press [Track] and [Record] to track and record the input of the Trackpad.
- A bad Trackpad will have a false press holding when pressure is removed, and/or it will not track finger motion accurately.
- A bad Trackpad should be replaced by an experienced technician, but it can be unplugged internally in an emergency.
3) Clean the Switches with Rubbing Alcohol or contact cleaner
If the switch is still intermittent or non-responsive, cleaning the switch with rubbing alcohol or contact cleaner (DeoxIt D5) is the next step.
- Turn off the Express console.
- Remove the black plastic keycap using a keycap puller or a thin pry tool.
- Note: Express keys are slightly larger than standard mechanical keyboard keys. If using a standard keycap puller, you may need to angle it to catch the corners of the keys instead of the sides
- Put a generous amount of rubbing alcohol over the exposed white switch surface and then press the switch many times so that the rubbing alcohol gets into the switch and reaches the corroded parts. *If using contact cleaner it is recommended to not over saturate the area. Try to direct cleaner between the white top and the switch base.
- Use forced air to clear out the liquid rubbing alcohol. (Eye protection and proper ventilation are recommended) *If using contact cleaner then soaking excess up with a shop towel will be suffice. Blowing air is not recommended since contact cleaner is not made to evaporate like alcohol.
- Turn the console back on and test.
