Express console not powering and chirping
If your console is chirping, there is excessive load on the power supply.  Two main causes of this are the Littlelites or an internal DC/DC converter.
Littlelites
If a Littlelite is shorted out,  too much current will be drawn from the power supply to the Littlelite circuitry. Remove one or both of the Littlelites and reboot the console.  If the problem stops, replace or repair the Littlelite that caused the problem. [ETC Part# M703]  DO NOT use High Intensity Littlelites.
DC/DC Converter
If your Express has a BNC "Thin Net" connector on the back, chirping and power issues can be caused by a bad DC/DC converter in the brick, designated PS1.  On Express consoles where thinnet is not required, PS1 (part number PS113) may be removed and replaced with a load resistor (R518).  The resistor is necessary to provide a dummy load across the 12V line of the power supply to insure proper voltage regulation. A heat sink (HS101) is also required.
After removing PS1, install the load resistor across pins 1 and 3 as shown below.  It’s mounted at an angle so the heat sink is as close to the PCB as possible.
Pin 1 connects to +12VDC, while pin 3 is normally not connected.  Install a jumper on the back side of the board between pin 3 and pin 12 to provide a ground connection.
Make sure that there is sufficient clearance between the heatsink and the wires coming out of the ETClink connector when reassembled.
