Editing a Subroutine in Express
To edit a subroutine, select the step you wish to change by pressing [S1], Step, and entering the step number. Use [And] and [Thru] to select multiple steps. You can either use softkeys to find your way around the Step Display or navigate with other console controls, as shown in the following table.
Navigation and Feedback - Step Display |
Select a step | ![]() |
Select a field | ![]() |
White row | selected step | |||||
Yellow field | selected field |
The softkeys available in the display are as follows.
[S2], Style | Allows you to select a style from the style menu. |
[S3], Select Cue | Allows you to enter a cue number for the selected step. |
[S4], Type/Level | Allows you to select a crossfade or an all- fade and to set intensity level. |
[S8], Up/Down/Follow | Allows you to set upfade and downfade times and to set follow time. |
Once you finish editing the subroutine, press [Record] [Enter] to save your changes.
95 If you select a range of steps, only cue steps will be selected. Style steps may only be edited individually and will be left out of selected ranges.
