Flexichannel settings in Express consoles
The console’s Command display can be set to operate in full display mode or in Flexichannel mode. In full display mode, channel displays show all channels and their current status. In Flexichannel mode, only channels with a recorded level or that are on the Link List appear. The console defaults to full channel display.
Follow these steps to enable or disable Flexichannel:
| Keystrokes: | Action: |
| 1. Press [Setup]. | Selects Setup display |
| 2. Select [1], System Settings, and press [Enter]. | Selects System Settings menu |
| 3. Select [9], Flexichannel, and press [Enter]. | Prompt reads: Enable/disable flexichannel (1 = Enable, 0 = Disable) |
| 4. Press [1] or [0]. | Corner reads: Flexi 1 Or... Flexi 0 |
| 5. Press [Enter] | Flexichannel mode is enabled or disabled |
