Labeling focus points on Express consoles
If you have Expression Off-Line, you may assign labels to your focus points. 65 Focus point labels can consist of any combination of letters, numbers and symbols and may be up to 16 characters long.
Follow these steps to label a focus point:
Keystrokes: Action:
1. Press [Blind]. Blind display mode
2. Press [Focus Point] [1]. Prompt reads:
Group mode – To recall a focus point, select the number and set it to a level
To create or modify a focus point, select the number and press ENTER
3. Press [Enter]. Prompt reads:
Select channel numbers
4. Press [Label].a Prompt reads:
Type focus point label (F6 = clear to end, F7 = previous focus point label, F8 = next focus point label)
5. Use the alphanumeric keyboard to enter a label. Corner displays your label
6. Press [Enter]. Focus point 1 is labeled
Not available on the Express console. You may type keyboard equivalent “B” in Expression Off-Line as a substitute for the Label key.
65 For information about Expression Off-Line and how to order it, see Expression Off- Line.
