Recording a multipart cue on an Express console
In the procedure below, one or more parts are recorded to a cue. The maximum number of parts you may record to a cue is eight. Follow, Link and Label attributes may be assigned to the overall cue.
Keystrokes: Actions:
1. Press  [Stage]. Selects Stage display mode
2. Press [S7], More Softkeys, until Part appears as softkey [S1]. Finds the Part softkey
3. Select channels, enter channel levels and press [Enter]. Prompt reads:
Select channel numbers
4. Press [Record]. Prompt reads:
To record cue, select number and press ENTER
To cancel, press CLEAR
5. Enter the cue’s number followed by [Enter].a
6. Press [S1], Part. Indicates the selected cue us a multipart cue
Prompt reads:
Select part number to record To cancel, press CLEAR
7. Enter the number of the part you want to record, followed by [Enter].b Records the part
Prompt reads:
8. Press [Rel] [Rel]. Releases captured channels
9. Repeat steps 2 through 8, adding channels for each part you want to include in the multipart cue. Records subsequent parts.
a If recording several parts to the same multipart cue, you do not need to enter the cue number for subsequent parts after recording the first part.
b You may select any part number in the range 1-8, regardless of previous parts recorded for this cue.
