Using Update to modify fade rate on Express consoles
You may also use the Update function to record manually modified fade rates into cues.
Follow these steps to update a rate for a cue running in a fader:
Keystrokes: Action:
1. Press [Rate] key for the fader in which the cue is running. Activates rate control
2. Move rate wheel to adjust fade rate. Fades are placed under control of the rate wheel. The Fader Status window shows the current rate
3. Press [S2], Update. Prompt reads:
To update cue, select number and press ENTER (TRACK + ENTER for tracking) (Press ONLY + ENTER to update only those channels already in cue)
4.Press [Enter]. New rate is recorded into cue
