Appropriate Gobo Size for Relevé Spot
XDLT Lenses are for LED use only and will be damaged if installed on an incandescent luminaire! Please click here for more information.
Lens Degree Pattern Holder Lens Type Model Number Part Number Color Frame / Donut Size Color Frame Model Color Frame Part # Donut Model Donut Part # Top Hat Model Top Hat Part # Half Hat Model Half hat Part #
90 Degree A or B
Standard 490LT 7060A2052-K 7.5" x 7.5" (190mm) 407CF 7061A3007 407DN 7060A1016 400PTH6 PCF1023 400PHH PSF1027
70 Degree Standard 470LT 7060A2051-K 7.5" x 7.5" (190mm) 407CF 7061A3007 407DN 7060A1016 400PTH6 PCF1023 400PHH PSF1027
XDLT XDLT70 7462A2009-K 7.5" x 7.5" (190mm) 407CF 7061A3007 407DN 7060A1016 400PTH6 PCF1023 400PHH PSF1027
50 Degree Standard 450LT 7060A2005-K
7060A2205-K
6.25" x 6.25" (159mm) 400CF 7060A3043 400DN 7060A1015 400TH PSF1021 400HH PSF1026
EDLT 450EDLT 7060A2049 6.25" x 6.25" (159mm) 400CF 7060A3043 400DN 7060A1015 400TH PSF1021 400HH PSF1026
LED EDLT LED50LT 7460A2008 7.5" x 7.5" (190mm) 407CF 7061A3007 407DN 7060A1016 400PTH6 PSF1023 400PHH PSF1027
XDLT XDLT50 7462A2008-K 7.5" x 7.5" (190mm) 407CF 7061A3007 DN7.5-2650 PSF1202 400PTH6 PSF1023 400PHH PSF1027
36 Degree Standard 436LT 7060A2004-K
7060A2204-K
EDLT 436EDLT 7060A2048 6.25" x 6.25" (159mm) 400CF 7060A3043 400DN 7060A1015 400TH PSF1021 400HH PSF1026
XDLT XDLT36 7462A2007-K 7.5" x 7.5" (190mm) 407CF 7061A3007 407DN 7060A1016 400PTH6 PSF1023 400PHH PSF1027
26 Degree Standard 426LT 7060A2003-K
7060A2203-K
EDLT 426EDLT 7060A2047 6.25" x 6.25" (159mm) 400CF 7060A3043 400DN 7060A1015 400TH PSF1021 400HH PSF1026
XDLT XDLT26 7462A2006-K 7.5" x 7.5" (190mm) 407CF 7061A3007 DN7.5-2650 PSF1202 400PTH6 PSF1023 400PHH PSF1027
19 Degree Standard 419LT 7060A2002-K
7060A2202-K
EDLT 419EDLT 7060A2046 6.25" x 6.25" (159mm) 400CF 7060A3043 400DN 7060A1015 400TH PSF1021 400HH PSF1026
XDLT XDLT19 7462A2005-K 10" x 10" (254mm) CF10 PSF1200 DN10 PSF1201 TH10 PSF1198 HH10 PSF1199
14 Degree Standard 414LT 7060A2050-K 7.5" x 7.5" (190mm) 407CF 7061A3007 407DN 7060A1016 400PTH6 PSF1023 400PHH PSF1027
XDLT XDLT14 7462A2004-K 10" x 10" (254mm) CF10 PSF1200 DN10 PSF1201 TH10 PSF1198 HH10 PSF1199
10 Degree Standard 410LT 7060A2001-K 12" x 12" (305mm) 410CF 7060A3069 410DN 7060A1028 410TH PSF1024
XDLT XDLT10 7462A2003-K 14" x 14" (356mm) 405CF 7060A3070 405DN 7060A1029 405TH PSF1025
5 Degree Standard 405LT 7060A2000-K 14" x 14" (356mm) 405CF 7060A3070 405DN 7060A1029 405TH PSF1025
XDLT XDLT5 7462A2002-K 17.5" x 17.5" (444.5mm) CF17.5 PSF1196 DN17.5 PSF1197 TH17.5 PSF1194 HH17.5 PSF1195
Zoom Lens Color Frame / Doughnut Size
15-30 Degree 7.5" x 7.5" (190mm)
25-50 Degree
Fixture Type Pattern Holder Color Frame / Doughnut Size
Source Four Jr. and Jr. Zoom M 6.25" x 6.25" (159mm)
Source Four PAR and MultiPAR None 7.5" x 7.5" (190mm)
Source Four Mini and Mini LED E 2.75" x 2.75" (70mm)
ColorSource Spot jr. M 5.45" x 5.45" (138mm)
Relevé Spot 1.79" (45.5mm) diameter None
