Replacing Main Control Module on a Relevé Spot
Replacing the Main Control Module
Steps
  1. Loosen the 4 screws attaching the module to the fixture
    Note that these screws are captured and will not fall out of the module
  2. Carefully remove the module from the fixture
  3. Follow the steps in reverse, installing your new Main Control Module and tightening the four screws
  4. Make sure that your Main Control Module is up to date, you can find the latest software version by clicking here
