Replacing Effects Module on a Relevé Spot
Replacing the Effects Module
Steps
  1. Unplug the following wires from the Motor Driver PCB
    • J12 - FX Module CAN
    • J6 - FX Module Power
  2. Loosen the 2 screws attaching the module to the fixture
    Note that these screws are captured and will not fall out of the module
  3. Carefully remove the module from the fixture
    Make sure that the Zoom and Edge lenses are away from the Effects Module to avoid collision
  4. Follow the steps in reverse, installing your new effects module and tightening the two screws
  5. Reconnect the wiring to the Motor Driver PCB
  6. Make sure to set the address on the fixture to the correct ID, for Effects, this would be 3.
    1. More Information about Motor Driver PCBs can be found here
