How to Program a Selador Control Card
Selador fixtures may need to be programmed when a customer wants the latest software versions or when the dimming curves do not match between fixtures because they have different control card software versions.
The software version should flash on the display right after the fixture is powered on, provided it's running a version newer than v1.9.
Selador fixtures cannot be programmed or updated using Updaterator, so please contact ETC Technical Services if your fixture needs to be re-programmed.
