My Source 4WRD-C Reboots After Changing its Starting Address
I change the starting address on my 4WRD-C either from the UI or via RDM, and it reboots and may not have saved the change.
It was found in v1.1.0 that if DMX is applied to the fixture and the start address is changed, sometimes it will reboot and may or may not save the address change. This bug has been logged and will be fixed in a future fw build.
  1. Unplug DMX, change the start address, then reapply DMX
  2. Downgrade the fixture to v1.0.0
