Source 4WRD and 4WRD PAR Safety Cable
Disclaimer: The ETC Safety cable P/N 7060A1022(-1), is to be used as a safety device for ETC lighting fixtures only.  It should not be used for rigging or lifting any items or people and should not be used under tension.
We highly recommend that all UL listed Source Four fixtures are secured with a safety cable.
This cable is a 30" long 1/8" diameter wire rope cable with snap clamp fitted. Safety specs for that cable are as follows:
Part Number 7060A1022(-1)
Safety Ratio 5:1
Wire Rope Breaking Load 2000lb.
Safe Working Load (SWL) 400lbs
