What Is the Wire Pinout of a Source Four Power Cable?
In the Source Four's tail, the wire coloring may be different than the black (hot), white (neutral), and green (ground) you are used to. There will likely be two white wires, and a green wire.
Color Purpose
White Hot
White Neutral
Green Ground
The two white wires connect to the Source Four lamp socket assembly, and are polarity independent, so it doesn't matter which get connected to hot and neutral.
