UV Output of Source Four Luminaires
Ultraviolet (UV) Content of ETC Source Four Luminaires
Introduction:
The safe use of Source Four luminaires to illuminate works of art, objects in a museum or similar delicate photosensitive objects requires knowledge of the ultraviolet radiation emitted. This document provides measured data for Source Four luminaires using a range of light sources and lenses to allow the lighting professional to make an educated judgment as to those emissions when creating a lighting design. It should be stressed however that, although care has been taken to ensure that these figures are as accurate as possible, there is no substitute for measuring the actual emission on site as local conditions may significantly affect the final result. These figures should be used for guidance only.
Methodology:
Representative sample luminaires were tested to the methodology suggested in IESNA RP-30-96 with three lamp versions to provide worst case results (See Note 2). These results were then extrapolated using known data to encompass other Source Four luminaires and other lamp varieties (Tables 1 and 2). To aid the application of the results, conversions and multiplying factors are also provided for different dimming levels of the luminaires (Table 3). Testing was carried out both with and without an Optivex™ UV filter in the luminaire.
IESNA RP-30-96 suggests defining UV for these purposes as all electromagnetic radiation with wavelengths between 300 and 400 nm and the luminaire?s total emission as the total radiation with wavelengths between 300 and 700 nm. This methodology was used for these tests and the results are presented in three different formats (Columns A, B and C) in tables 1 and 2:
Column A UV percent (%): This expresses the total UV energy between 300 and 400 nm as a proportion of the total energy between 300 and 700 nm.
Column B Microwatts of UV per lumen (µW/lm): This expresses the UV energy emission relative to the luminous output.
Column C Microwatts per square centimeter at 50 lux (µW/cm2): Unlike the first two figures this is an absolute measure and is referred to the lighting level of 50 lux often recommended for photosensitive display materials.
Source Four Ellipsoidal (See note 1 below)
      Without filter With Optivex filter
      A B C A B C
Lamp Code Watts Volts Color Temp % UV uW/lum uW/cm2 At 50 lux % UV uW/lum uW/cm2 At 50 lux
MasterColor 150 N/A 4000K 4.50% 163 0.82 0.84% 25 0.13
MasterColor 150 N/A 3000K 1.82% 61 0.30 0.52% 17 0.09
HPL 750/77 750 77 3250K 2.65% 160 0.80 0.61% 36 0.18
HPL 550/77 550 77 3250K 2.65% 160 0.80 0.61% 36 0.18
HPL 550/77X 550 77 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 750/115 750 115 3250K 2.65% 160 0.80 0.61% 36 0.18
HPL 750/115X 750 115 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 575/115 575 115 3250K 2.65% 160 0.80 0.61% 36 0.18
HPL 575/115X 575 115 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 375/115 375 115 3250K 2.65% 160 0.80 0.61% 36 0.18
HPL 375/115X 375 115 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 750/120 750 120 3250K 2.65% 160 0.80 0.61% 36 0.18
HPL 750/120X 750 120 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 575/120 575 120 3250K 2.65% 160 0.80 0.61% 36 0.18
HPL 575/120X 575 120 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 750/230 750 230 3200K 2.48% 150 0.75 0.57% 33 0.17
HPL 750/230X 750 230 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 575/230 575 230 3200K 2.48% 150 0.75 0.57% 33 0.17
HPL 575/230X 575 230 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 375/230X 375 230 3000K 1.84% 111 0.56 0.42% 25 0.12
HPL 750/240 750 240 3200K 2.48% 150 0.75 0.57% 33 0.17
HPL 750/240X 750 240 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 575/240 575 240 3200K 2.48% 150 0.75 0.57% 33 0.17
HPL 575/240X 575 240 3050K 1.99% 120 0.60 0.46% 27 0.13
HPL 375/240X 375 240 3000K 1.84% 111 0.56 0.42% 25 0.12
Table 1
Note: This data is applicable as worst case data for the Source Four, Source Four jr, Source Four Zoom and Source Four jr Zoom Ellipsoidal luminaires when fitted with the standard, EDLT or zoom lenses.
Source Four PAR (See note 2 below)
      A B C A B C
MasterColor 150 N/A 4000K 5.41% 295 1.48 0.87% 44 0.22
MasterColor 150 N/A 3000K 2.22% 96 0.48 0.57% 24 0.12
HPL 750/77 750 77 3250K 3.80% 235 1.18 1.12% 66 0.33
HPL 550/77 550 77 3250K 3.80% 235 1.18 1.12% 66 0.33
HPL 550/77X 550 77 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 750/115 750 115 3250K 3.80% 235 1.18 1.12% 66 0.33
HPL 750/115X 750 115 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 575/115 575 115 3250K 3.80% 235 1.18 1.12% 66 0.33
HPL 575/115X 575 115 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 375/115 375 115 3250K 3.80% 235 1.18 1.12% 66 0.33
HPL 375/115X 375 115 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 750/120 750 120 3250K 3.80% 235 1.18 1.12% 66 0.33
HPL 750/120X 750 120 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 575/120 575 120 3250K 3.80% 235 1.18 1.12% 66 0.33
HPL 575/120X 575 120 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 750/230 750 230 3200K 3.55% 220 1.10 1.05% 62 0.31
HPL 750/230X 750 230 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 575/230 575 230 3200K 3.55% 220 1.10 1.05% 62 0.31
HPL 575/230X 575 230 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 375/230X 375 230 3000K 2.64% 164 0.82 0.78% 46 0.23
HPL 750/240 750 240 3200K 3.55% 220 1.10 1.05% 62 0.31
HPL 750/240X 750 240 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 575/240 575 240 3200K 3.55% 220 1.10 1.05% 62 0.31
HPL 575/240X 575 240 3050K 2.86% 177 0.89 0.84% 50 0.25
HPL 375/240X 375 240 3000K 2.64% 164 0.82 0.78% 46 0.23
Table 2
Note: This data is applicable as worst case data for the Source Four PAR EA, Source Four PAR MCM and, Source Four PARNel luminaires when fitted with any of the standard lenses.
Reduction of UV output with dimming (Incandescent lamps only).
Dimming an incandescent lamp reduces the UV output in two ways; firstly the overall output of the lamp reduces and, secondly, the percentage of UV emitted further reduces as the lamp runs cooler. For a range of dimming from 100% down to 50% the UV output is approximately as indicated in table 3.
Dim level (voltage) 100% 95% 90% 85% 80% 75% 70% 65% 60% 55% 50%
UV output relative to output at full voltage 100% 90% 81% 72% 64% 56% 49% 42% 36% 30% 25%
Table 3
Notes to the data:
  1. All reported data are average UV values (300nm-400mn) based on full power operation with the lamp operating at rated voltage.
  2. Calibrated lamps were used for all tests
  3. The primary tests from which these results were derived were carried out by Independent Testing Laboratories Inc (ITL) Boulder, CO on:
    1. Source Four ellipsoidal luminaire fitted with a 26° standard lens and three lamp types: HPL 115V 750W 3250K incandescent lamp, MasterColor 150W 3000K metal halide lamp, and MasterColor 150W 4000K metal halide lamp
    2. Source Four PAR EA luminaire fitted with an NSP lens and three lamp types: HPL 115V 750W 3250K incandescent lamp, MasterColor 150W 3000K metal halide lamp, and MasterColor 150W 4000K metal halide lamp
      Data for other lens/lamp combinations was extrapolated from these and other data by ETC. These two fixture types and three lamp types represent the worst cases for UV output for the Source Four product lines.
  4. Relative UV output was measured at 7 points across the field and those results averaged to produce the typical results reported here. This data therefore represents the "average UV" across the projected field.
Optivex™ is a trademark of Applied Coatings Group.
