How to put Source 4 Series 3 Fixture into Burn In Mode
Note: This mode is used by ETC and is completed at the factory during final test. The only time this should be used by a customer or dealer is when directed by ETC.
First Step
Plug fixture into power source.
Second Step
While fixture is powering on press and hold the green and red button knobs simultaneously. A screen will come up that gives you the option to select burn in mode. Select burn in mode.
