Source Four LED Series 3 Serial Number Location
There are two places to find the serial number on a Source Four LED Series 3 fixture. One is found through the UI on the rear of the fixture, and the other is found on a physical label. See the instructions below for finding both options.
Serial Number in the UI
  1. Press the Menu Button to enter the Main Menu
  2. Adjust the the Intensity Encoder (indicated in blue) to highlight "Diagnostics" and press in the Intensity Encoder to enter the Diagnostic Menu.
  3. With  "About Fixture" highlighted, press in the Intensity Encoder.
  4. The number will be listed on the line that says "S/N: XXXXXXXXX", where the X's are a nine digit number:
Serial Number Label
If you look through the grate on the underside of the fixture, you'll find a while label affixed to the light engine on inside. This label will have a P/N (part number), S/N (serial number), and barcode.
