What is the orientation of the lens in my 36 degree XDLT lens tube?
Some lenses for 36 degree XDLT lens tubes used in June 2022 are missing the blue dot to denote lens type and aid in orientation.
This applies to the 36 degree lens tube only. If you look at the lens from the side, one side has more of a curve than the other. The flatter side faces towards the fixture side of the lens tube.
