ETC File Extensions by Product
Architectural
Paradigm
Detailed information on Paradigm file types
Extension Description Version
ELP Paradigm Project Working File (The primary file in 1.x. Used as a background file from LD 2.x to 4.1.0. Use eliminated in LD 4.2.0) 1.0.0 - 4.1.0
SELP Paradigm Server Project Working File (Used as a background file for Server projects in LD 2.x through 4.1.0. Use eliminated in LD 4.2.0) 2.0.1 - 4.1.0
PCF Paradigm Configuration File (non-Server systems) 1.0.0 - Current
SPCF Paradigm Server Configuration File 2.0.1 - Current
LCDCONF Touchscreen Configuration 1.0.0 - Current
LCDTHEME Touchscreen Theme File 1.0.0 - Current
TAR.GZ Paradigm Processor or Server Log File 1.0.0 - Current
CDP LightDesigner / ControlDesigner Crash Dump File 4.2.0 - Current
ODT Open Word Processor Document 1.0.0 - Current
ODS Open Spreadsheet Document 1.0.0 - Current
Echo
XML EchoAccess Configuration
CFG ERP, ERP-FT, Sensor IQ, EchoDIN Configuration
EACP Echo Architectural Control Processor (E-ACP) Configuration
JSON EchoTouch Controller Configuration 2.5.0 - 2.6.0
LSF EchoTouch Controller Configuration 3.0.0 - Current
EFW Echo Station Firmware Update
Mosaic
MDP Mosaic Designer 1.0 Configuration 1.0.0
MTC Mosaic Touch Editor Files 1.0.0
MSM Mosaic Media Manager 1.0.0
MD2 Mosaic Designer 2.0 Configuration 2.0.0
DAT Mosaic Designer 2.0 Interface File 2.0.0
Echoflex
XML Garibaldi Configuration
XLSM Pre-Commissioning Sheet
GPF Garibaldi Pro Configuration
Legacy Unison
BIN Firmware Update
CFG Architectural Configuration File
BMP ULCD graphics
DAS/ACS/ALP
There are no file formats exchanged. All DAS configurations are either built by the LCD or flashed on an EPROM at the factory. ACS and ALP configurations were flashed on an EPROM at the factory.
AAS
There are no file formats saved. All configuration is done on the processor locally.
Eos Family
ESF EOS Show File 1.0.0 - Current
ESF2 EOS Show File with Compression 2.9.0 - Current
ESF3D EOS Show File with Augment3d 3D Data Included
3.x+
Eos v2.9.x and below will not display files with the extension .esf3d in the Eos File Browser.
Eos v2.8.3 and below will not display files with the extension .esf2 in the Eos File Browser.
On ETCnomad systems, it is possible to double-click a showfile to directly launch Eos Nomad and attempt to open that file.  Attempting to open a .esf3d file in v2.9.x and below may clear the previous show's data from Eos, but then the .esf3d file will fail to load with an Unsupported file extension error.
Cobalt (and Congo) Family
ASC Congo/Cobalt Show File
4.x.x - 7.x.x
8.x as Export
CSF Cobalt Show File 8.0.0 - Current
CFG Congo/Cobalt System Settings Backup File 6.x.x - Current
DEF User Template Library Definitions Backup File 7.0.0 - Current
Net3 Radio Focus Remote (RFR) / Wired Focus Remote (WFR)
DFU RFR Base Station and Remote (RFR/WFR) Firmware Update
ColorSource Family
JSON ColorSource Show File 1.0.0 - 2.6.0
LSF ColorSource Show File 3.0.0 - Current
JLIB ColorSource Fixture Library File
CueSystem
GDS Firmware Update
Express/Expression Family
BIN Software Update
SHW Express/Expression Show File
There is a non-ETC made program called Sunlite Pro that also uses the .shw file extension.  Please note that these files are not compatible with Express/Expression/Insight consoles or offline software.
Emphasis
ECS Emphasis Show File
Obsession Family
DAT Obsession Show File Saved to Disk (ETCSHOW.DAT)
DIR Obsession Shows Directory Saved to Disk (ETCSHOWS.DIR)
PER Obsession II Moving Light Personality
Smartfade Family
ASC SmartFade Show File
BIN SmartFade ML Personality Library (ETC created one is named "perslib.bin")
Lighting Fixtures
ArcSys RDM
S Update Firmware
ColorSource Fixtures
S Update Firmware
Desire/Source 4 LED
S Firmware Update
Fos4 Studio
BUN Update Firmware
Relevé
NARCHIVE Relevé Update Bundle File
Revolution
S Update Firmware (both MCC and SCC)
Source 4WRD
S Firmware Update
ETCPad
JKS Specific Apps/Firmware that run on ETCPad
Concert
CCF Concert Configuration File
(can still be opened in 3.0.0+ but if saved will convert to CCZ)
1.0.2 - 2.1.0
CCZ Compressed Concert Configuration File 3.0.0 - Current
Can Import and/or Export: CEM+, CEM3, and Echo PCP Mk1 and Mk2 Configuration Files
Net3 Gateways
BIN Update Firmware
Net3 Gateway Configuration Editor
GCE Saved Configuration File
CSV Import/Export of Device Settings
ETCNet2 Configuration Editor
NCE Saved Configuration File
CFG NICPicker Configuration File (Must be EtcNet2.cfg and saved in the System32 folder)
ETCNet2 Nodes
BIN Update Firmware
Response Gateways
S19 Firmware Update
BIN Firmware Update 6.0.1-7.x.x
DMX/RDM Gateway (Mk 1 Only)
ColorSource Distribution
S Firmware Update for DMX Out Ports
ColorSource ThruPower
SREC Update Firmware
ColorSource Wireless and DMX Relay
BIN Radio Firmware (Wireless Units Only)
HEX Application Firmware
ColorSource Wireless Transmitter
Foundry
S Update Firmware
DRd
DRD Dimming Engine Configuration
Source 4 Dimmer
S Firmware Update
LMI Racks
There are no file formats exchanged. All custom configurations were flashed on an EPROM at the factory.
Matrix Mk2
BIN Merger Firmware
IMG Processor Firmware
Sensor3
BLD Update Firmware
ETC Dimming Configuration File
Sensor+
BLD Update Firmware
DIM Dimming Configuration File
XML Sensor+ Connect Export of Dimming Configuration Files
.RAK Sensor.rak Configuration file from Sensor+ Connect Export
.RM Arch.rm Configuration file from Sensor+ Connect Export
.PRE Preset.pre Configuration file from Sensor+ Connect Export
.PAN Panic.pan Configuration file from Sensor+ Connect Export
.r1 loads.r1 Configuration file from Sensor+ Connect Export
Sensor Classic
SEN Dimming Configuration File 3.x
BIN Dimming Configuration File 2.x
Smart Dimming (SmartBar, SmartPack, SmartSwitch)
S Update Firmware
