Terminating DMX Wiring with Screw Terminals
Preparation
The DMX termination kits for Screw Terminal are:
Weidmuller (orange) 8-pin: 4100A1012
Weidmuller (orange) 3-pin: 4268K1002
CUI (blue) 8-pin: 4100A1022
CUI (blue) 3-pin: 4100A1023
CUI (blue) 3-pin DMX2 4 port: 4100A1026
CUI (blue) 3-pin 90̊  Set of 7 for EDBC-6: 7180A1012
CUI (blue) 3-pin 90̊   7180K1023 DMX Prep Kit W/90D Screw Connector
Cat5/6 wiring should never be terminated via Phoenix (green) or Weidmuller (orange) screw terminal connectors. CUI (blue) screw terminal connectors have been validated and are acceptable for use with Cat5/6 cable.  For information on terminating DMX over Cat5/6 in systems with Weidmuller connectors, please see Terminating DMX Over Cat5 Wiring with IDC.
Required Tools:
  • Wire Strippers
  • 2.4mm (3/32") flat blade screwdriver
  • Heat source for heat shrink
  • Flush-Cutting diagonal cutters
  • Cat 5/6 Cable Jacket Wire Stripper (for outer jacket)
Topology:
  • Less than 500M (1640 feet) of Belden 9729 or equivalent per DMX line.  See Cable Cross Database for equivalents.
  • Daisy Chain/Linear topology
  • Less than 32 devices per DMX line including the controller
  • Noted as "D" or "X" cable type on ETC submittals
Kit includes:
  • 4x 1.5mm (1/16") heat shrink, 178mm (7") length
  • 4x 4.8mm (3/1") heat shrink, 38mm (1-1/2") length
  • 2x 9.5mm (3/8") heat shrink, 51mm (2") length
  • 2x 4.8mm (3/16") heat shrink, 25.4m (1") length
  • 6 4" wire ties
  • One screw terminal header
How to:
Category Cable and Alternate Belden 9729 diagram
