Cannot Change IP Address in Net3 Concert
Devices appear in Net3 Concert, but the IP address field is grayed out and cannot be edited.
Net3 Concert may be in Live Edit Mode.  Check the tool bar in the top-left corner (default location) of the window.  The Live Edit icon is the green square with a wrench.
  1. Deselect the Live Edit Icon. clipboard_e55f50d29c1c8390dbce726ce0a658437.png
  2. Select the device in question, and the network settings should now be available for change.
  3. After changing the IP address of your gateway, you will need to send the config to the device. With the device selected, navigate to Network>Send Device Configuration or right-click the device and click Send Device Configuration in the context menu.
