Concert Software Version History
Concert Software Versions
Version
click for release note
Release Date UpdaterAtor Version New Device Packages Improvements Download Compatibility
4.7.5
2026-09-11 7.0.1 -
  • Bug fixes
  • macOS:
    • 11.6.5 and later
  • PC:
    • Windows 11
    • Windows 10
  • Consoles:
    • Windows 10e
    • Windows 7e
4.7.4 2025-11-04 6.4.1
  • Foundry Switch Panel (Connect and Report)
  • Response 0-10V Gateway R3
  • Updates to CEM3 and F-Drive RX device packages
  • Bug fixes
4.7.3 2025-07-22 6.4.0
  • F-Drive RX
  • Response Mk2 (CPU2) 8-port DMX Gateway
  • Preferences option to use default web browser
4.7.2 2025-05-19 6.3.2
  • Desire Fresnel 5
  • Updates to Paradigm device packages
4.7.0 2025-03-31 6.3.1
  • ColorSource PAR V Zoom
  • Improvements to Sensor3 (CEM3) including:
    • Save CEM3 configurations to Conductor
    • Show/Hide Dimmer Double patch columns in Dimmer Properties
    • Set Levels and Circuit Check now use circuit numbers
    • Option to enable/disable sACN or DMX when adding new rack from Device Library
    • Import multiple CEM3 files at the same time
    • Syslog IP properties exposed
4.6.0 2024-10-31 6.3.1
  • Installer no longer requires running multiple times when updating from an earlier version of Concert
  • Component manager improvements
  • If downgrading from 4.6.0+ to a previous version, Concert must be manually uninstalled first.
4.5.1 2024-07-30 6.3.0
  • ColorSource PAR Jr
  • fos/4 Panel
  • fos/4 Fresnel
  • Updated Response Mk2 Gateway and Response MIDI/SMPTE Gateway device packages
4.5.0 2024-03-15 6.3.0
  • Response Mk2 CPU2 DMX Gateways
  • Response SnapBack
  • ColorSource Spot VXT
  • Error dock now includes columns for Model and IP Address
  • PCP Mk2 now provides MAC address information
  • Devices that use file-based configs are temporarily restricted from using copy/paste (i.e. PCP Mk1/Mk2, F-Drive)
4.4.0 2023-10-27 6.2.0
  • PCP Mk2 (v4.1.0)
    • Online editing
4.3.0 2023-02-09 6.1.0
  • Gadget II CPU2
  • PCP Mk2 (v4.0.1)
    • Offline editing only
  • Hand Pan tool for grab-and-drag style of movement in the World View
  • Advanced Input Patch (AIP) copy from another device
  • RDMnet protocol support (preview feature only)
  • Graphical optimizations
  • macOS:
    • 10.14.3 and later
  • PC:
    • Windows 10
    • Windows 8
    • Windows 7
  • Consoles:
    • Windows 10e
    • Windows 7e
4.2.0 2022-03-24 6.0.3
  • Eos Apex consoles
  • Ability to toggle between light and dark display themes
  • ODS export from spreadsheet view
  • Improved 4K monitor support
4.1.2 2021-09-16 6.0.3 -
  • Bug fixes for large networks and macOS device package updates
4.1.1 2021-04-29 6.0.1
  • ColorSource Relay Multiverse
4.1.0 2021-02-18 6.0.1
  • F-Drive R12
  • F-Drive W1
  • Response Serial Gateway
  • Removed "Net3" from title, now just "Concert"
  • Support for macOS
  • Bug fixes and optimization
4.0.2 2019-06-27 5.3.0
  • Response Mk2 (CPU1) DMX Gateways
  • PC:
    • Windows 10
    • Windows 8
    • Windows 7
  • Consoles
    • Windows 7e
4.0.1 2019-05-29 5.3.0
  • Echo Expansion Bridge
  • ArcSystem RDM devices
4.0.0 2019-01-31 5.3.0 -
  • Spreadsheet column configuration
  • Changed parameter values in Spreadsheet and Property Editor are now easily identifiable (Note that this feature is limited for CEM+)
  • Deprecation of XP support
3.1.0 2018-10-04 5.3.0 -
  • Reduced application loading time
  • Added Fast RDM Discovery feature
  • Additional bug fixes and optimization
  • PC:
    • Windows 10
    • Windows 8
    • Windows 7
  • Consoles:
    • Windows 7e
    • Windows XPe
3.0.0 2018-05-10 5.3.0
  • PCP Mk1
  • CEM3 (v1.7.0)
  • ColorSource Spot/PAR Pearl
  • Irideon FPZ/WLZ
  • Response MIDI Gateway
  • Redesigned Welcome page, tab operation and new Concert logo
  • Eos and Cobalt console device detection
  • Redesigned Device Operations for supported ETC fixtures
2.0.3 2017-19-21 5.1.0
  • CEM3 (v1.6.1)
  • Bug fixes for device configuration and synchronization
2.0.2 2017-03-30 5.1.0
  • Net3 DMX Gateways (v7.0.0)
  • Support for RDM queued messages via Gadget to support ColorSource Wireless Relays
  • Corrects an issue where device packages could not be loaded on Windows XP or XP Embedded
2.0.1 2016-10-27 5.0.1 -
  • Bug fixes for installing new device packages
2.0.0 2016-07-21 4.4.0 -
  • New, more uniform icon design
  • Major performance improvements to the underlying network engine
  • Progress bars per device in Component Manager when configurations are sent or received
  • Ability to sort and search lists of discovered devices or items in the Spreadsheet view
  • Ability to edit, lock, align, and distribute graphical items in the Workspace view
  • Ability to archive and restore CEM3 system configuration
1.1.2 2015-10-29 - -
  • Bug fixes for Cobalt consoles running 7.2+
  • PC:
    • Windows 8
    • Windows 7
  • Consoles:
    • Windows 7e
    • Windows XPe
1.1.1 2015-04-23 - -
  • Bug fixes for ETCnomad Puck
1.1.0 2015-03-12 - -
  • Added Find Unreachable Devices feature
1.0.9 2014-10-10 - -
  • Default version for CEM3 changed to 1.5.1
  • Resolved re-image issue with Cobalt consoles
1.0.8 2014-07-28 -
  • Net3 DMX Gateways (v6.0.1)
  • PC:
    • Windows 8
    • Windows 7
1.0.7 2014-04-24 -
  • Net3 1-port Gateway (RDM)
  • CEM3 (v1.5.1)
1.0.4 2014-01-16 -
  • FDX3000
  • CEM3 (v1.5.0)
  • Bug fixes
  • PC:
    • Windows 8
    • Windows 7
    • Windows XP SP2
1.0.3 2013-11-14 - -
  • Bug fixes
1.0.2 2013-08-22 -
  • Net3 DMX Gateways (2- and 4-port)
  • Net3 1-port Gateway (no RDM)
  • CEM3 (v1.4.0)
  • CEM+ (v3.1.x)
  • P-ACP
  • P-CCS
  • Conductor
  • Initial release
Function Description Setting
This table will not appear in the article and is used to configure the search function.
Number of Tables Prior to Search
( Integer: 0-99 )
This function determines the index of the HTML table where the search should begin. It counts the number of tables that precede the search function.
Note: KMS templates ("Caution", "Disclaimer", "Important") contain tables.
1
Search Bar Placeholder Text
( String )
The non-permanent text that serves as a hint or an example of the expected input to be entered by the user. filter results by version number, release date, new device packages, or improvements
Hide Non-Matching Rows
( true / false )
This function hides the rows in a table that do not contain any text matching the search input. true
Show Table Title
( true / false )
Show or hide the element immediately preceding the table when a match is found within the table. In many articles, header elements are used to identify the following table.
Example: Paradigm Version history article
true
Highlight Matching Text
( true / false )
Highlight the matching text in yellow. true
Hide Rows with Spanned Columns (2+)
( true / false )
Automatically hide rows that contain cells spanning two or more columns. This ensures a consistent and organized presentation of the data.
Example: Product family rows in the Flat Rate article are hidden.
true
Show Table Headers
( true / false )
When a search function matches a query within a table, this function will display the corresponding header row of the table to provide context and improve readability. true
Product Line Prefix
( true / false )
Looks for search terms that start with a product line prefix followed by 'XXXX'.
Example: Flat rate article and Packing Kit article. 7184A1234 matches 7184AXXXX
false
