| 3.1.2 |
2026-11-04 |
6.1.0+ |
- Added Configuration Migration feature
- Bug fixes
| 3.1.1 |
2026-05-12 |
6.1.0+ |
| 3.1.0 |
2025-11-20 |
6.0.1 |
- Alerts include more specific information on devices and errors
- Digest now has an editable email body
- Improvements to editing of Rules
- Errors Table shows RDM ID for RDM devices
| 3.0.2 |
2021-02-05 |
5.0.0—6.0.1 |
- Bug fixes
- Support for Response Mk2 gateways
- CEM3 configuration backup
- Removal of Apache Tomcat 6.0
| 3.0.1 |
2019-10-31 |
4.2.2—4.2.4 |
- Bug fixes
- Energy management data older than 1 year is no longer automatically deleted
| 3.0.0 |
2018-02-28 |
4.0.0—4.2.1 |
- Added Energy Management feature
- Energy Management requires Rev B (7180A1160) or C (7180A1170 or 7180A1180) hardware (see Conductor Hardware Revisions)
- 3.0.0+ can still be installed on Rev A or Rev B (7180A1150) hardware, but this feature will not be available
Conductor must be running software version 3.0.0 for compatibility with Paradigm server configurations running firmware 4.0.0 and higher. If Conductor is running 2.1.0, it can be upgraded with an upgrade USB, but if it is running 2.0.0 or below it will need to be reimaged.
| 2.1.0 |
2016-06-13 |
3.0.0—3.1.2 |
- Alert function now supports SMS, UDP, HTTP Post, and contact closure events (through original Net3 I/O Gateway only) in addition to email
- Added RDM logging and ability for RDM errors to trigger alerts
- Ability to define static routes for each NIC
- View all allocated IP addresses on a subnet, including static and dynamic
- Advanced configuration of time zones, including custom time zones
- View current system errors in web UI
- Download system logs as a .tar.gz file
- Ability to password-protect Conductor web UI
- Multiple languages available for web UI
| 2.0.0 |
2014-11-06 |
2.1.3 |
- Fixed the "Shellshock" vulnerability in Conductor's OS
- Tabs added to the web UI
- Can now upgrade firmware from the internet or from a local USB drive
- Access ACN-compatible devices using hostnames rather than device IP addresses
- Added the Learn Network Devices feature
- Added integration service for APC® UPS devices
- Added support for wake on LAN
| 1.2.1 |
2013-12-05 |
2.1.1—2.1.2 |
- Initial release for standalone Conductor (without P-CCS)
| 1.2.0 |
2013-11-07 |
2.1.0 |
- Added email alerts
- Storage of config files for other ETC devices on the network (Paradigm, Eos, etc.)
- Added logging of system power usage
- Added server capabilities for several network services
- DHCP (automatic IP assignment)
- SNTP (network time service)
- SMB and FTP (file sharing)
| 1.1.0 |
2013-05-03 |
2.0.5 |
| 1.0.2 |
2012-09-06 |
2.0.3—2.0.4 |
| 1.0.1 |
2012-02-23 |
2.0.1—2.0.2 |
