Remote Interface Unit (RIU) and Remote Video Interface (RVI) Jumpers and Dipswitch Guide
REMOTE INTERFACE NODE PCB [4052B5014]
Switches are either On (Closed) or Off (Open).
The Remote Interface does not use DIP switches 7 or 8 .
DIP switch 1 must be Off and 2 must be On or the Remote Interface will not start.
| Main DIP Switch Function (S1) | ||
| 1 | Factory Use Only | Off (Open) Normal operation |
| 2 | Factory Use Only | On (Closed) Normal operation |
| 3,4,5,6 | DMX512 Addressing | |
| Off, Off, Off, Off | Ports 1-3 (1-1536) | |
| Off, Off, Off, On | Ports 4-6 (1537-3072) | |
| On, On, On, Off | Ports 7-9 (3073-4608)* | |
| 7 | Unused | Off (Open) Normal operation |
| 8 | Unused | Off (Open) Normal operation |
*4600 DMX Outputs only supported with Obsession II systems
Network Jumpers for Rev A PCB (J22)
Locate jumpers 1 through 14.
BNC (Thin-Net) connections
Install jumpers 1 through 6
Jumpers 7 through 12 are not installed.
RJ45 (UTP-Twisted Pair) or DB15 (ThickNet) connections
Install jumpers 7 through 12
Jumpers 1 through 6 are not installed.
Jumper 14 should always be on. Jumper 13 must always be Off.
Network Jumpers for Rev 0 PCB (J22)
BNC (Thin-Net) connectionsInstall jumpers 9 through 14
Jumpers 3 through 8 are not installed.
Install only jumpers 3 through 8
Jumpers 9 through 14 are not installed.
Jumper 1 must always be On. Jumper 2 must always be Off.
Check Power Supply Voltage
Verify that the Node Card is getting proper DC voltage by metering between TP1 and Com. You should get 5.05vdc between these two points. If not adjust voltage at the power supply so that you get 5.05vdc between TP1 and Com.
REMOTE VIDEO INTERFACE--PROCESSOR PCB [4053B5001]
| Main DIP Switch Function | ||
| 1 | Factory Use Only | On (Closed) Normal operation |
| 2 - 5 | Factory Use Only | Off (Open) Unused |
| 6,7 | Factory Use Only | On (Closed) Normal operation |
| 8 | Factory Use Only | Off (Open) Unused |
Network Dipswitch settings for Rev A and Rev 0 PCB
Locate the two sets of DIP switches, visible through the right side panel of the RVI.
Set the back six DIP switches to On (up)
Set the front six to Off (down).
RJ45 (Twisted Pair) connector or the DB15 (ThickNet) connector
Set the front six switches to On (up)
Set the back six to Off (down).
