Differences Between ETC's Gateway Lines
Use the chart below to help identify the differences between ETC's Net 3 ACN, Mk 2, and Mk 2 gateway lines.
References
Feature
Net3
1-Port
Response Mk 2
1-port
Net 3
2-port
Net 3
4-port
Response
Mk 2
2-port
Response
Mk I
4-port
Response
Mk 2
4-port
Response
Mk 1
1/4-Port DIN
Response
Mk 2
DIN (1-/2-/4-port)
  Net3 1 Port.png MKII 1 port.png Net3 2 port.png Net3 ACN 4 Port.png MK II 2 port.png Response 1 4 port.png Response MK2 4 Port.png MK ONE 4 Port Din.png MK 2 DIN.png
Ethernet
10/100 MPS
Yes Yes Yes Yes Yes Yes Yes Yes Yes
PoE
(IEE 802.3af)
Power Supply
8-28 VDC External power supply. 8-28 VDC External power supply.
PS406-F
PS406-F
PS406-F
PS372
PS406-F
PS372
Portable Variant Available Available Available Available Available Available Available No No
Touch To Wake Sensor No Yes No No Yes No Yes No Yes
Screen No Yes Yes Yes Yes Yes Yes Yes Yes
Local Configuration No Yes No No Yes No Yes Yes Yes
sACN Sources 12 per GW 8 per port 12 per GW 12 per GW 8 per port 12 per GW 8 per port 12 per GW 8 per port
Screen Type No OLED Backlit LCD Backlit LCD OLED Backlit LCD OLED  Backlit LCD OLED
Max Addresses 512 512 1024 2048 1024 2048 2048 2048 512/1024/
2048
Back Box Size US 1 - gang
(3.5" deep)
US 1 - gang
(3.5" deep)
US 2 - gang
(3.5" deep)
N/A US 1 - gang
(3.5" deep)
N/A N/A N/A N/A
Connector Options XLR5 Female/Male XLR5 Female/Male XLR5 Female/Male,
8 Pin Terminal Block
XLR5 Female/Male,
XLR5 Female/Male XLR5 Female, 8-pin terminal, 3 XLR in - 1 out XLR5 Female/Male, 3-pin Terminal Block, RJ45 8-pin Terminal Block 3-pin Terminal Block
Screw Terminal Connector Included No No No No No No Yes No Yes
Colors Black Black, White, Gray, Cream Black Black Black, White, Gray, Cream Black Black Gray Gray
