Net3 DMX/RDM Gateway Versions
Description
The table below lists every version of gateway software (sometimes called firmware) and its corresponding release date.
You can click the release date to download that version's release note.
Related Links
Filter:
Net3 and Response DMX/RDM Gateways
Version Release Date Key Enhancements Supported Hardware Software Download
7.1.0.9.0.5 October 31, 2019
Improvements to RDM implementation and optimizations to the gateway firmware
UpdaterAtor
7.0.1.9.0.17 November 30, 2017
Optimization for updating older versions of gateways and fixes existing issues
UpdaterAtor
7.0.0.9.0.11 March 30, 2017
Adds support for additional RDM transactions (ACK_TIMER) which support RDM products including the ETC ColorSource Relay. The software is migrated to a newer version of the underlying operating system and is improved through the resolution of software defects. This release also adds support for the Response DALI Gateway.
This version and subsequent ones remove support for "Switch to Net2 Mode"
UpdaterAtor
6.0.1.9.0.4 July 17, 2014
Fixes a vulnerability in the firmware update process for the Net3 Only varieties of ETC’s DMX/RDM gateway. When any version of firmware below 6.0.1 is loaded into ETC's gateways with Net3 only hardware, there was a small risk that the gateway would lose bootloader and require return to the factory for service.
This is the last version that supports the "Switch to Net2 Mode" on Gateways that can run in Net2 Mode
UpdaterAtor
6.0.0.9.0.2 April 24, 2014
Support for ETC Net3 DMX/RDM One Port Gateway
Not Available
5.1.1.9.0.18 January 16, 2014
Support for larger number of RDM messages in the RDM queue, removal of RDM Standby functionality, and bug fixes
  • Net3 Two and Four Port Gateways
UpdaterAtor
5.1.0.9.0.16 July 10, 2012
Dimmer Doubling Support, S4 LED and Desire software update port mode, and universe on the gateway displayed in place of port number.
UpdaterAtor
5.0.0.9.0.4 June 15, 2011
Adds support for a hardware component change in the Net3 Two Port and Four Port Gateways.
This version does not include an image for ETCNet2 devices - it should not be installed in devices running ETCNet2
UpdaterAtor
4.3.2.9.0.2 August 22, 2013 Bug Fixes UpdaterAtor
4.3.1.9.0.2 October 18, 2012 Adds configuration from Gateway Configuration Editor (GCE) and corrects defect in bootloader TFTP which could cause gateway to start an endless update cycle UpdaterAtor
4.3.0.9.0.16 July 17, 2012 Added configuration from Gateway Configuration Editor Not Available
4.1.0.9.0.15 June 24, 2010 Adds support for receiving both draft and ratified sACN and sends in ratified sACN. UpdaterAtor
4.0.3.9.0.31 May 11, 2007 Added DHCP support for Net3 Four Port Gateway in Net2 mode only
  • Net3 Four Port Gateway
Not Available
4.0.1.9.0.15 June 24, 2010 Adds support for receiving both draft and ratified sACN but continues to send in draft sACN for backwards compatibility UpdaterAtor
4.0.0.9.0.17 June 30, 2006 Initial release of Net3 Four Port Gateway in Net2 mode only
Not Available
4.0.0.9.0.10 July 23, 2008 Initial release of the Net3 One Port Gateway UpdaterAtor
3.1.0.9.0.4 June 24, 2010 Flexible Output Patch and add support for ratified Streaming ACN
UpdaterAtor
3.0.0.9.0.19 April 29, 2010 Receives both draft and ratified Streaming ACN but defaults to sending draft sACN (for compatibility in existing systems which have not yet updated)
UpdaterAtor
2.0.0.9.0.14 April 16, 2009 Adds support for RDM and bug fixes
UpdaterAtor
1.0.0.9.0.83 March 6, 2008 Initial Release of ACN support of Net3 Two and Four Port Gateways
Not Available
