Net3 Gateway Output Set to Address Other than 1
What happens if I set the start address on a Net3 Gateway output to be a number other than 1?
For example, if you were to set the output to be Universe 1 Address 101, what would happen?
Answer: When the gateway receives sACN on Universe 1 Address 101 it will output DMX at Address 1. This is essentially an output offset.
