What are the specs for a Net3 Gateway external power supply?
ETC sells replacement power supplies directly (see Related Links/References). However, any power supply that meets the specifications below should work to power Net3 gateways that support an external power supply.
Specs
- 100-240VAC (input power)
- 12VDC (output power)
- 1.5A (output amperage)
- 5.5mm OD / 2.5 mm ID (barrel dimensions)
