How Do I Wire a Contact Closure to the Response Analog I/O Gateway?
I have an On/Off contact closure that I want to use with my Response Analog I/O Gateway as an input.
Explanation of Issue
The Response Analog I/O Gateway can accept any 10V input as a closure or measured value. If your contact is a "dry" contact and does not provide its own 10V, the Gateway's +10V can be used.
Dry Contact (no voltage provided by contact)
  1. Land one side of the contact to the desired input number.
  2. Land the other side of the contact to the Gateway's +10V
Wet Contact (10V provided by contact)
  2. Land the other side of the contact to the COM next to the input
