Response Opto Din Rail Manual Shows Power Termination Incorrectly
I'm not sure how to terminate power to my Response Din-Rail mount Opto splitter, the provided manual does not match the label printed on the unit.
Explanation of Issue
The first revision of the Response Opto splitter documentation incorrectly states how to terminate power.
The manual shows users should terminate as "Ground, Minus, Positive". This is incorrect
The correct power termination is "Positive (+), Minus (-), Ground"
The label printed on the unit is correct for all generations of Din Rail opto splitters
This misprint was corrected in revision B of the manual.
