Response Mk2 Gateways do not act as a standalone merger/splitter without a perceived network connection
Response Mk2 Gateways do not act as a standalone merger/splitter without an active network connection.
Explanation of Issue
Due to the way a Mk2 gateway processes data, it will not act as a merger or splitter without a valid network connection.
If you would like to use the Mk2 Gateways as a 1-in 3-out opto-splitter, you need to have some form of connection on the network port. We have confirmed that this can be as simple as an Ethernet Loopback plug. These are available online or as ETC P/N SGN1272. Alternatively, you can create an RJ45 loopback by connecting pin 1 to pin 3 and pin 2 to pin 6.
If the gateway has a network connection, and that connection is lost, it will continue to work as an opto-splitter until a power cycle. At that time if no network connection or loopback is present it will stop working as a standalone merger/opto.
RDM Data
When a Response Mk2 Gateway is used to to merge or split DMX data with no network connection, RDM data will not be passed.
If situation requires RDM data, you will need an RDM-compatible device such as a Response Opto-Splitter.
