Testing Output on Mk2 Gateway Causes Other Ports to Drop Out
When using the Test Output feature on any of a Response Mk2 Gateway, other ports will briefly stop outputting.
Enabling test mode on a Mk2 gateway will cause each other port to stop outputting data for a short period of time (<1s). There is not a workaround for this issue, so if you are testing an output, ensure that you can safely interrupt DMX on the other outputs.
