Disable SMPTE Transmission
Description
The Response SMPTE Gateway is configured with a Source ID which can be set 0 to 32.  Setting the source to 0 disables ACN output from the SMPTE Gateway.  This is displayed in Concert:
Using Concert, the Response SMPTE Gateway can be configured to send SMPTE via UDP to one specific IP address and port.  UDP can then be disabled by setting the Port to 0 - Concert will show 'Off'
Related Links/References
  • Concert configuration help is available inside Concert software under Help > Device Help > SMPTE Gateway
