I3M I5M outputs flickering
The output on one or more of the phases are flickering.
The smoothing capacitor(s) on the voltage rail are not functioning properly causing the 5v rail to flucuate. This causes the output to "flicker".
Replace C1, C3, C5, C7 with 1000uf 25v capacitors. ETC part number: C383.
