Response OPTO-Splitter
The OPTO-Splitter allows a single DMX-512 line to be translated to a star configuration. The unit has 5 separate DMX-512 Outputs and optically isolates every Output from each other as well as the Input for ground fault isolation. The unit also provides a DMX Thru connection for insertion in the middle of a DMX chain. It is available in 19-inch, 1U EIA rack mount or portable versions.
