WYSE 50 Terminal Settings for Response Products
Enter setup mode by holding down the [SHIFT] key and pressing the [SETUP] key at the same time.
Settings must be as follows in order for the terminal to work correctly:
The settings in BOLD are the settings that need to be changed from factory defaults
Response Network Controller
| Page 1 | HANDSHAKE = XONXOFF | SCREEN = 80 | CURSOR = BLOCK | BLINK? = ON | MODE = FDX |
| Page 2 | DATA BIT = 8 | STOP BITS = 1 | PARITY BIT = NONE | MODEM PORT BAUD RATE = 38400 | |
| Page 3 | BLK END = US/CR | AUTO NL = ON | CR = CR | AUTO SCRL = ON | AUX BAUD R = 9600 |
| Page 4 | SCRL = JUMP | STATUS = ON | S.SAVER = OFF | PROT = DIM | TEST = OFF |
| Page 5 | KEYS? = US/UK | RET/ENTER = CR/CR | COMPATIBLE MODE = WY50 | ENHANCE = OFF | |
2212
| Page 2 | DATA BIT = 8 | STOP BITS = 1 | PARITY BIT = EVEN | MODEM PORT BAUD RATE = 19200 | |
Use the [ARROW] keys to move the highlight bar through all the parameters.
Press the [SPACE BAR] to toggle through the possible settings for each parameter until the correct one displays.
When you are done, press [SHIFT]+[SETUP] again to return to normal mode. Press [Y] to save changes.
Do not press [STARTOVER] or [ESC] while in setup. This returns all settings to their factory defaults.
