LED Indicator States for ThruPower modules
Introduction
The data below outlines the indicator states on 120v or 230v ETC ThruPower Modules (TR20AF/TR20SAF/ETR15AFR)
120v ThruPower LED States
  • Green Signal light indicates the control signal from CEM3.
  • Red Power light indicates output of the dimmer.
  • Green LED to the right of the ThruPower switch indicate relay is switched on.
  • Amber LED to the right of the ThruPower switch indicate local switch is on.
Dimming mode set remotely from CEM3
Relay Mode set remotely from CEM3 (green LED).
Local Switch engaged, no control from CEM3 (amber LED).
Local Switch engaged, with CEM3 control on (amber LED green Signal indicator).
ThruPower LED States 230V
Local Switch engaged, with CEM3 control on (amber LED & green Signal indicator).
