UFD Foundry dimmer default set to Forward phase and not Reverse/auto
Out of the box, my Foundry Phase Adaptive Dimmer is set to Forward Phase, not Auto / Reverse Phase.
In 2020, the default phase setting for Foundry Phase Adaptive Dimmers was changed to forward phase. This was done to reduce the likelihood of damaging the device when it is connected to a Magnetic Low Voltage load.
If reverse phase dimming is required, use Concert to change the phase mode over RDM.
